so wondering if I could get some input on choosing between the solar edge or the enphase solar inverter . I have a few solar estimates a couple installers like the solar edge and I one likes the enphase .
If you start with a centralized inverter (e.g. Solaredge) you may still be able to expand later by adding panels and microinverters.Hopefully I can get All my output from my garage roof but it is attached to the house so I assume that I would need the RSD. I like the idea of the mirco inverter Incase I need to expand in the future.
This is true. You could add on to a Solaredge system with micros, and sometimes it's the best option available.If you start with a centralized inverter (e.g. Solaredge) you may still be able to expand later by adding panels and microinverters.
That is what I've done. We started with a central 8.5kW system and have added other panels and microinverters to increase overall output.
I like the idea of buying some spare panels also. I wish I had. Panel size is not as standard as many seem to think. When I added 6 panels to our existing 30-panel array it was tough to find some that matched.
You can even use the spare panels in other odd locations with microinverters if you like. We plan to use one of ours for an entry cover.
I think the older Solaredge stuff was pretty solid. My Solaredge SE5000 inverter and 20 optimizers on my 5.4 kw system will hit 6 years this May and I have had zero issues with them.Happy to offer some thoughts and experience.
I have been in the solar industry since 2012 and in that time I have installed and sold both kinds of inverters mentioned in the OP. Many installers used the Enphase M series micro inverters for several years until they started noticing a high failure rate, at which point a lot of them switched to using the Solaredge inverters with DC optizers. The Solaredge inverters worked well for a while, then a few years ago, installers started noticing the failure rate increase on the Solaredge inverters to the point that the company I work for started moving away from Solaredge and using the new line of microinverters from Enphase, the IQ series which had been totally redesigned from the old M series. We have been installing the Enphase IQ series micros for a few years now and have had very few failures so far.
Here is something to think about when making your decision. If one microinverter fails, the rest of the system keeps working and only the one panel with the bad micro doesn't produce any energy until that micro can be replaced. If you go with the Solaredge string inverter and it fails, the whole system is down until the inverter can be replaced. Installers are busy and can't always get out to replace a bad inverter immediately, and sometimes have to wait for a replacement inverter to be shipped out to them, so you could have several weeks or more of lost production while waiting for a new inverter.
A word about warranties. The Enphase micros come with a standard 25 year warranty while the Solaredge inverters have a standard 12 year warranty with an option to purchase an extension up to 25 years for a few hundred dollars extra. Some installers will include the warranty extension in their proposal.
My personal experience: I have a Solaredge inverter that was installed in March of 2020. It failed at almost exactly the one year mark in March of 2021. The replacement has been working fine since then and Solaredge did acknowledge a bad batch of inverters and says they have worked to fix the issues, but only time will tell.
They seem to have a lower failure rate of the optimizers versus microinverters.I think the older Solaredge stuff was pretty solid. My Solaredge SE5000 inverter and 20 optimizers on my 5.4 kw system will hit 6 years this May and I have had zero issues with them.
Sounds like you have one of the older A series Solaredge inverters. If you look at the sticker with the model number and serial number, does the model number end with A or H? Example: SE5000AI think the older Solaredge stuff was pretty solid. My Solaredge SE5000 inverter and 20 optimizers on my 5.4 kw system will hit 6 years this May and I have had zero issues with them.
Its the A series with the screen.Sounds like you have one of the older A series Solaredge inverters. If you look at the sticker with the model number and serial number, does the model number end with A or H? Example: SE5000A
If it's an A series, I agree that those were more reliable and robust, but I don't have enough evidence to make a blanket statement that it was definitely when they changed to the "HD Wave" or H series that the reliability issues started. It was around that timeframe, but there were other factors at play, such as Solaredge ramping up their manufacturing to meet demand, so it could be something else, but in general I do think the older A series inverters we're more reliable, though I have seen some of them fail too.
Update:My personal experience: I have a Solaredge inverter that was installed in March of 2020. It failed at almost exactly the one year mark in March of 2021. The replacement has been working fine since then and Solaredge did acknowledge a bad batch of inverters and says they have worked to fix the issues, but only time will tell.
