Last night a fellow called me on a Craigslist Want ad I had been running, looking for Whitfield Prodigy parts
He tells me that he has an exact stove like the one I posted as an example (my stove)
We chat a few minutes and then get down to business.
Seems that the stove will not run except on the high setting.
I explain that I am looking for parts and will take it off his hands if we can come to terms.
I told him that I bought a complete working Whit prodigy in 2010 for $200 and was not interested in any big cash outlays.
He was local so I agreed to stop by and take a peek today.
I show up about 9 am and we go to take a look.
Well now, it turns out not to be a prodigy, but instead an Advantage 2 T made in 1993.
LOOKS GOOD, sooooooooooooo, I paid the man the $200 and we loaded it up.
I get it out of the Suburban and on the Patio and go after it cleaning it up.
The mechanical cabinet is chocked full of pellets, to the point that the room air fan had sucked some in and plugged the fan up.
There was a total of nearly 1/2 of a 5 gallon bucket of pellets in the mechanical cabinet
Ended up yanking the fan off to clear it all out.
The control panel was full of pellets as well.
Pulled all the sheet metal off and between the air hose and the vacuum cleaner it is now spotless.
Yanked the ash trap baffles out and cleaned there too (NOT BAD THERE )
Finally ready to plug it in.
I push the start button and the room blower comes on and the draft fan struggles and stops.
I select the 2 feed position and the exhaust fan again struggles and stops.
After getting the heat selector on 5 the draft fan finally spins up enough that I could hear some air coming out the exhaust in the back.
I select back to position 1 and again the draft fan dies
OOOOOOK
I checked the draft fan and its very stiff and will not spin free.
Gave the fan lube holes a shot of WD40 and within a few moments the fan is whizzing along like the breeze.
Tomorrow I will get some good lube in those bearings.
Would seem that nobody lubed the fan bearings recently if at all.
The stove is in really lovely shape.
I need to install a new ash pan gasket is all.
The feed cycle is spot on and all the rest of the goodies seem to work dandy
Again, another case of a complete lack of cleaning claimed it's victim.
What is really sad was the fact that the owner had called a stove tech to fix it.
I can't believe anyone would not or could not figure this situation out.
Anyway, I did not get any Prodigy parts, but did get a very lovely Advantage 2
OOOOOOK
My Quest Plus had seen a lot more heavy use, and I paid what corresponds to $500.
