A few years ago I posted a question asking how I could move the heat from my wood stove into my other rooms. Suggestions were posted from those in-wall fans to setting a fan on the side of my stove to a Peltier chip driven fan as well as a fan placed on the floor in the room forcing cold air back into the warm room thereby pushing warm air back into the cold room. I do heat my house with my wood stove through the winter and enjoy my house being on average 76-78 degrees. So, I did go with an Eco fan and a fan place along side my stove as well as a small 10" fan placed on the floor at the door in the cold room. Just recently the 2 speed Lasko small fan on the floor (in the cold room) would not run on the higher setting for more than an hour or two. So I figured it was tome to replace it. I have to mention this fan did move the air into the room but not as well as I wanted. So I started to shop for another small fan and cam across an XPOWER P-80A Mini Mighty Air Mover/Floor Fan. It's basically takes up the same amount of space on the floor as the small fan but moves air incredibly better. When I ran the Lasko fan I would have a 10 to 12 degree lower temp in the colder room and in the morning it would take almost 3 hours to get to a comfortable temp of 68°. With my new fan on the lowest setting the room is 8° lower and in the morning I'll bump it up to the #2 setting and within 40 minutes the cold room is with in that 8° and sometimes only 6° lower reaching as high as 73°.
So my suggestion here is spend a few more dollars and be more comfortable with an air moving fan instead of just another small fan.
![[Hearth.com] Circulating The Heat [Hearth.com] Circulating The Heat](https://www.hearth.com/talk/data/attachments/273/273275-9bdf79ab3ad3ab92dbc5acf28ea8013d.jpg?hash=7LyE5nA0dH)
