Circulation Fan System Advice/Specifics
I suppose the fan is, but the auger grinding isn’t.
It does warm the cabin though. And it is super convenient for each of us to bring a bag of pellets and chip in to heat the weekend.
Most of the time I only need the combustion blower going, except if I'm heating when it's -20C out. Yes, on mine once every minute it feeds pellets. You can hear the motor, pellets falling, and sometime clicking sounds. I have yet to sleep in the basement where the stove is. I can still hear it going though in the winter, as it right below me. Plus, I have 4 inch duct between the two levels. That is one thing I like about it. Just buy bags of pellets (hopefully good ones), clean it (PITA) and run.
A pellet stove is a small, solid-fuel furnace at heart, with many of the same components as an oil furnace. In our pellet stove there were two fans, convection and combustion, in addition to the auger motor. In addition to the fan noises there was the low roar of the fire itself. One can sort of get used to it, but we had to turn the tv up in order to overcome the pellet stove noise.
Well I had an insulation guy come out, and he doesn't recommend adding anything. He says we're still looking pretty good for 13" in most spots, which would be R30 or more. They could add a skiff on top, but it's his opinion that we wouldn't notice a heating or cooling benefit.
Hm.
And did he check air sealing?
Having a gap of 1/16-1/8" between the drywall and the top plates of walls adds up to a few square feet hole from your living space to the attic. And then there are the lighting and cable penetrations etc.
If he didn't look at air sealing, he's not worth your dollars.
R30 is reasonable though. Not my original R19, but not excellent either.
