I am planning on putting an Evergreen Lopi Stove into a brick alcove. The brick alcove is located on the exterior of the house. The face of the alcove is drywall and plywood inside the house.
My questions is this. As long as all combustible material stays outside of the combustible clearance range does it matter if noncombustible material is attached to that combustible material and passes inside that range? Or does having that noncombustible materiel attached to the combustible material change the clearance requirements?
Basically Im planning on replacing the combustible wall above the alcove with horizontally placed Metal studs and then cement board on top. I would keep the wood studs on the sides of the alcove as they meet the combustible clearance range but I would plan on attaching the metal studs and cement board to them. We are hoping to have something that looks similar to the below image. If we do a mantel it will also be non combustible.
