I purchased and installed this stove Nov 19th fired it up on highest setting as directed to set paint. Heated up, not much paint smell AND then I turned it to the lowest setting, to my dismay nothing happened sounded just like it was on high. I spent hours reading trying to find info but as you know no much out there. Turned the stove off and called Cleveland Stove and waited for over a week to hear back (Thanksgiving got in the way ) I sent E-mails customer service a few times called again and again, I started trying to figure it out as I sold my older stove, no luck Finally a return call and was told I cannot use the eco2 mode that turns the stove down I need to have it turn off, I will need to invest in ignitors Was told there is very little change in fan speeds from the highest to lowest settings I am so disappointed I was able to turn down fan speeds but only a very little amount. If I set the setting on P1 and down to P4 I can hear a small change in blower speed, air temps do change 225 degrees on low 325 degrees on high temp, that is so hot Im afraid to use it if not home or at night and only on low. Bottom line this little stove could heat 2000 sq ft I hate it and am going to try to return it. I hope the folks at Cleveland read this. I have not tried the wifi I'm having enough trouble with
I purchased and installed this stove Nov 19th fired it up on highest setting as directed to set paint. Heated up, not much paint smell AND then I turned it to the lowest setting, to my dismay nothing happened sounded just like it was on high. I spent hours reading trying to find info but as you know no much out there. Turned the stove off and called Cleveland Stove and waited for over a week to hear back (Thanksgiving got in the way ) I sent E-mails customer service a few times called again and again, I started trying to figure it out as I sold my older stove, no luck Finally a return call and was told I cannot use the eco2 mode that turns the stove down I need to have it turn off, I will need to invest in ignitors Was told there is very little change in fan speeds from the highest to lowest settings I am so disappointed I was able to turn down fan speeds but only a very little amount. If I set the setting on P1 and down to P4 I can hear a small change in blower speed, air temps do change 225 degrees on low 325 degrees on high temp, that is so hot Im afraid to use it if not home or at night and only on low. Bottom line this little stove could heat 2000 sq ft I hate it and am going to try to return it. I hope the folks at Cleveland read this. I have not tried the wifi I'm having enough trouble with it.
Hi, I have the same stove. I run it on eco1. I’ve had it about a month now and all was well until a few days ago when it started being finicky. I am wondering what the blowers should be set at to make it run more efficiently and somewhat keep the glass clean? I saw in another post someone said vent blower at 15 and room blower at 10. Mine are at 4/3 right now but the manual is no help at all and customer service hasn’t called me back! Then last night it shut off on its own in the middle of the night. I woke up cold. It hasn’t been a fun day.
It also says in the manual I should clean the heat exchanger once per week. I have to clean my stove every day or every other day as I have it running continuously. Do I have to take the sides of the stove off to get at the heat exchanger?? That’s how I read the manual…
