How many people get a large coals bed after burning in there wood burning stove.. like after around 3-4 hours of burning?
How bout maple ?Depends on species of wood, air flow, and moisture content of wood.
And what types of wood are you burning ?I get nothing but fine ash with some species and more solid black charcoal with others.
Maple typically doesn't coal excessively for me.How bout maple ?
Maple doesn’t coal much. Increase air flow and check your moisture content.How bout maple ?
Or decrease airflow. I sometimes get a large coal bed when pushing the stove hardMaple doesn’t coal much. Increase air flow and check your moisture content.
Wait after 3 to 4 hours of burning. That is probably just normal coaling stage. Your only half way through the loadHow many people get a large coals bed after burning in there wood burning stove.. like after around 3-4 hours of burning?
Oak gives me an excessive amount. I’ve learned to mix it on the coldest days since burning it over 3 days or more, the pile takes up too much room with little heat output. I only get a normal amount from an established fire after 3 or 4 hours. It has to burn 24/7 for 3 days to accumulate to the point of needing extra air to burn down.How bout maple ?
At 4 hrs after starting a full load in a Summit there should be a lot of solid wood still left. If it is all coals the fire needs to burn down more or the air turned down more and earlier.How many people get a large coals bed after burning in there wood burning stove.. like after around 3-4 hours of burning?
Thank youAt 4 hrs after starting a full load in a Summit there should be a lot of solid wood still left. If it is all coals the fire needs to burn down more or the air turned down more and earlier.
