Help
  Had a Vermont Casting Radiance direct vent propane stove installed over the summer.  Works fine, but if I do not have the stove on all the time, ice forms on the vent pipe and wall metal plate just inside the house, and then it all melts when the stove is turned on.  I have humidity in the house at 30%.  I saw them install the venting and when I questioned them, they assured me it was a normal way of doing it and typical install from a kit.  They cut a roughly one square foot hole in my wall and installed the double walled pipe in there in a metal sleeve and that sleeve is only a thin piece of metal on the outside and the inside, so the -20 to -40 weather just freezes that inside metal panel and the vent pipe.  Shouldn't there be a non combustible square plug in the wall inside that metal sleeve with the vent pipe going through it?  Its like I have a square foot hole in my wall, the only difference is that there are two thin metal sheets covering it.  This is not right.......  and I paid really good money to have the local pros install it.
