I had a FireplaceX Elite insert installed last winter but I had some concerns from the very beginning about some parts of the installation.
In particular I did not like the way the insert was connected to the liner. The installer put a couple of bolts and then he just put some refractory cement around it.
Towards the end of the season I realized that, while the insert was running, much heat was coming out from the crack between the fireplace and the cover plate of the insert and I guessed the heat was coming from the insert-liner connection.
Yesterday I disassembled the front cover of the insert and that is what I found (check picture below). The cement was all cracked and there is not much holding the two parts together.
I am also worried because the old surrounding of the fireplace is wood and having all this heat escaping towards the wood frame does not make me feel very safe either.
Is this the best way to connect the liner to the insert?
Are there better and more robust ways (clamps, ....)?
Thanks
![[Hearth.com] connect insert to liner [Hearth.com] connect insert to liner](https://www.hearth.com/talk/data/attachments/134/134488-b3797aff12a923a254f132233c9489f9.jpg?hash=s3l6_xKpI6)
Thanks
