I just bought (from Lowes) and finally installed a Century 1000 (CFM FW240007) into our basement. I tied it into a 6" stainless chimney liner that runs 23' through the middle of the house and crests at the peak of the roof. I have absolutely no problem with draft. Couldn't ask for better. The problem is that I am having problems controlling the air to the stove. The damper control at its highest works very well, but when I damper down, there seems to be very little change. It appears that it is getting air from somewhere else other than air control on the front. At first I thought it was the door gasket because there was that tiny little gap where the two ends meet, but rhen I realized that the air was coming from below. After using a butane lighter to locate the draft, the air is coming from around the edges of the masonry ash pan cover inside the firebox.
Does anyone use that opening to remove ashes? I don't use mine, nor do I plan to. I have always removed ashes with a shovel and bucket. Is it acceptable to use stove cement, or firebrick mortar to seal that opening?
I am sure that I am not getting the lowest setting out of my air control beacuse of that draft. Any suggestions?
