rwhite
Have a buddy who does pizza on his stove. Uses a stone and very large cast iron skillet as a lid. Gets everything hot 1st the throws the pie on for 5-10 minutes. I haven't ever tried one but they look good.
I line with plenty of aluminum foil. That's the trick to keep splashes off the pretty top lolHow do you keep your stove top and pipe so shiny?
That's what I need! A good percolator! Off to amazon I go LOLReally no temperature control so the only thing I have cooked on the stove in the last few years is dried pinto beans in a dutch oven to soften them.
I use the stove primarily to humidify the house with 2 pots of water constantly going and in the morning to percolate coffee.
BTW I recommend the 8 cup Farberware pot. Its around $20.That's what I need! A good percolator! Off to amazon I go LOL
Sent from my SM-G935T using Tapatalk
No, I'm referring to inside the stove like directly on the coals with the door shut. btw, thank you for my 800th likeI purchased a 15 inch skillet and the pan pizza works well in the oven but I have yet to try it on top of the woodstove
I like that one but the handle could present a problem if you double it up for camping use if you are careless. If you also intend to use it for camping a graniteware pot probably would be a safer choice.This one?
How does it do with lower stove top temps?With as warm as its been I have been running it pretty low ( 300's )
With regard to desired stove temp my jotul castine needs a minimum of 370 on the upper left thermometer for water to boil.This one?
I think I'd just use my regular stove burner with it camping and not put it in the fire. I love roughing it but the wife needed hotel quality while camping lolI like that one but the handle could present a problem if you double it up for camping use if you are careless. If you also intend to use it for camping a graniteware pot probably would be a safer choice.
So, all I can think of to do is soup, and actually was only going to keep it warm on the stove, after cooking it in the kitchen where it is convenient. Do I put it directly onto the wood stove, without a trivet, or anything? Am I going to scratch up the Oslo's blue-black enamel? Center or corner? (we didn't buy the cooking oval thing).
What else do you cook on or in your stoves?
No, I'm referring to inside the stove like directly on the coals with the door shut. btw, thank you for my 800th like![]()
We tried this and found that direct contact with the coals and the pizza stone burnt the crust. Better to let the coals burn down then insert a couple bricks several inches apart and set the pizza stone on top of the bricks. It'll be hot inside the stove so watch the pizza closely. You may need to rotate it once for even baking. Ours cooked up the pie in 2 minutes.So you use the inside of the stove as a pizza oven? I take it you have a small bed of coals and just add a little wood when you need some? Or do you slide the coals away and let the bricks do the cooking?
