Hello! I'm new here and am hoping someone can help me with a few questions about a wood stove pipe coming from a corner install on the main floor (new construction just started building). Originally, I had thought wouldn't it be neat to get a little heat from the pipe coming through the floor into my master bathroom right in the corner where my bathtub would be located. But, recently our local wood stove guy told me that in Maryland after you run a double walled pipe through a 12" ceiling support box you must then switch to class A pipe and it must be enclosed in a framed structure with a minimum clearance between the outer pipe and inner framing of 2". He's saying all together the exterior of the enclosure will be 18" square because of the width of the 2 x 4s, etc.
First: Is there no type of pipe that I can use in my bathroom that wouldn't require an enclosure after it clears the floor and tub until it has to be put through another 12 ceiling support box before going into the attic? I actually wanted the look of an exposed pipe in the corner of the bathroom....
Second: Why does the enclosure have to be 18" wide? Can't we use something else to attach dry wall to other than 2 x 4's? Like maybe a metal frame? It's important the enclosure, if truly required, be as small as possible as there isn't that much room before the tub starts.
Third: This has to do with the pipe after it gets into the attic - if I run it straight up and through the roof, it will be a horribly tall and ugly chimney. I have to shift the pipe towards the ridge of the gable roof to decrease the size of the chimney. So, I will need to add two bends to get it where we need it. My wood stove guy is saying that will have a bad effect on the draft and built up creosote etc. But, that pipe is going to be over 35 feet long! I can't imagine draft being a problem! I had an old VC stove in the basement of my first home and it had 2, 45 degree angles going up about 30 feet and the draft was awesome.
Any advice would be appreciated - thanks!
