Corrosion in Central Boiler wood furnace
airsepta
2
Colorado
We recently bought a house with a CL5036 Central Boiler wood furnace. I drained some water from the tank into this water bottle and there is a pale orange color, so I am assuming there is a bit of corrosion going on. Anyone with more experience with this equipment know how "bad" this is and if we can have normal operation as long as we do a refill with proper amounts of corrosion inhibitor added?
brenndatomu
8,117
NE Ohio
The water color by itself doesn't mean much...no way to know it was totally clean when installed.
Our well has high iron, but is fine with using iron out salt in the softener, even so it tends to shed some buildup if you sudden draw a bunch of water, like filling the boiler.
There's really no way to be sure the boiler is totally fine on the water side.
I'd drain, refill, treat/test the water n run it.
Reactions: flyingcow
airsepta
2
Colorado
Interesting point on how the well might react to a sudden draw of 200 gallons, hadn't considered that. Everything looks pretty good during normal uses, and we can fill a 40-50 gallon bathtub without getting any discoloration, so I'd guess it went in pretty clear but can't be entirely sure.
salecker
2,088
Northern Canada
Being a CB it is an open system so testing and treating the water should be an annual event.
flyingcow
2,563
northern-half of maine
Obviously everyone’s well is not the same.
But if you’re able to fill a bath tub without issues, a 200 gal draw shouldn’t be an issue. Just turn the tap on low. As was pointed out, fill n sample to get the proper ph and corrosion inhibitors in place.
I’ve filled my inground pool twice over the last 18 yrs. 28,000 gals. Took a few days, all went “well”😏.
The well is a 220 ft drilled well. Usually water is 20 ft from the top of the casing.
Reactions: sloeffle
