I know we have some knowledgeable folks here, and was hoping to take advantage of the collective wisdom.
I've just finished building a cottage and am really struggling with the flooring. It's close to Lake Michigan, and the relative humidity is always 50% - 80%. We keep the place open when we are there and closed up when we aren't. We don't have AC, and keep the heat about 40F during the winter.
The floors are 3/4" maple, and within two months of installation started cupping and even buckling in some places. They are a mess.
My neighbors all have solid wood flooring, no AC or dehumidifiers, and have not had a single problem. I've got a dehumidifier in there now, but am looking for a long-term solution. I was thinking now that they have swollen up, if I go back and cut additional expansion gaps along the edges, the buckling would likely settle down.
Thanks in advance for any suggestions.
in the winter is get your entire floor to behave as one piece of wood, shrinking & expanding with the seasons & temperatures. Then you will simply need to install thick enough baseboard & trim to accommodate the size changes. Note this is not normal wood glue but rather a glue that has a high tack (holds on to what it touches) as well as high elasticity (plenty of stretch) & a wide temperature tolerance (won't become brittle when cold, wont run like water when hot). Best to use a hardwood flooring shops glue as they make their living at this & can't afford under performing glues. BTW use different company than the installer above as your options should have been explained to you prior to buying & installing a product. Providing of course that you explained the situation at the cabin to them.
Eh?!
!. And in certain homes it fits the charm/character and is really really nice! If my house were older, victorian or colonial style, I would want a floor like that.
