Laying out location for new country hearth. It requires 25 inches in front clearance this kinda pushes the hearth out in room a bit. Is this much clearance common? I will do what is required for proper install just curious. Thanks
Oy! Second US stove manual error in the same number of weeks. This appears to be really wrong. The documentation appears to be poor with these stoves. Contact them to get it right. I will start a conversation with the US Stove rep here on hearth.com. Someone needs to proofread their manuals. Lord knows what other errors they have in them. Here is their customer service rep's email: [email protected]
OK, my bad Cbob. I confused Pleasant Hearth 2000 (GHP) with Country Hearth 2000 (USSC). They are different stoves and different contact points. I've PM'ed Owen from USSC to look into this and clear up what appears to be errata.
The UL standard’s testing confirms the requirement of thermal floor protection to extend that far.
Straight from engineering (our head guy there has this unit in his house BTW)
I think that is the only EPA stove where I have seen this requirement. Why the big difference? From what we hear here most people will balk at a hearth that deep. The stove doesn't appear to be radically different in design or size from the rest of the market. What makes it unique?
Not sure Engineers don't give answers like me and you would...lol. That first line above was a copy and paste right from their E-Mail I'm going through the OM's for the other 20+ stoves and see if any others are over 18"
those stoves both the 2000 & 2500 produce a ton of heat through the door / glass area, I have the 2500 and its a heater, I would follow all clearances and not cut corners with these stoves
For sure follow the manual's hearth requirements. This is just a first for me. Haven't seen a 25" hearth in front of the door since the pre-EPA days. I don't understand how this stove would radiate so much more heat out the front when it's design is so standard.
