Everyone always says creosote forms at the top of the stack.  Makes sense flue gasses start hot from the stove and then cool traveling to the top.  Has anyone seen the opposite?  I clean top down and I notice far more creosote at the bottom in the T and directly above than I do at the top.
A very knowledgable Woodstock employee told me that it could be my T isn't air tight. Or some connection is loose down low. This is would cause cold room temperature air leaking into and causing creosote down low. I checked all my connections and they seem tight.
Just wondering if anyone else had this problem and found a solution?
