I have an old school vigilant, and it serves me well until it gets below 20 degrees then it becomes something to offset my furnace, 20-30 degrees works great at keeping the whole house comfortable, 30-40+ degrees almost too much stove, at that outside temp it can get the room the stove is in up to the mid 80's.
So now I am thinking it has more to do with the house than the stove at those temps, insulation, air leaks etc.
But what I am curious about and cant find a post on it out here is when its in horizontal burn what are people seeing with avg flue temps. When I kick mine into horizontal you hear that great sound of the secondary kicking in, then my flue temps drop as expected. But they tend to always settle out at 200-300 degrees, which is fine when its above 25 outside, but when it gets colder than that outside I almost always have to run it in vertical mode.
I don't use griddle temps anymore just flue temps, because I want to make sure I am keeping the flue over 250 as often as I can (not to mention that stove will bury a griddle thermometer at 900 deg with out hesitating and will throw the calibration of it off to the point that when the stove is out it will still read 1-200). I don't kick the horizontal or afterburners in, until I am at 3-400 and sometimes higher on the flue temps to make sure my chimney is warm all the way to the top. Also I should mention that if it has run in horizontal for a long time over night when I am at work etc. I make it a habit to run it in vertical for about 30 mins and get the flue as hot as i can for as long as I can in that 30 mins to dry out any creosote that may have formed from running in horizontal.
When it is in horizontal I have the secondary air port open all the way and the thermostatic damper open all the way too, if I don't do this and leave the thermo one at half way then the temps tend to drop below 200 which is very bad.
I have tried propping the thermo damper open to see if that creates higher flue temps but nothing it always maintains a range of 2-300 so I assume that is where the stove is happy and wants to be lol
But I am curious to hear what others are seeing for flue temps on their VC stoves
thanks
thanks
