Posted this on tractorbynet & thought I would also give it a shot here.
My 15 year old CC has been having intermittent problems turning over. This is on a 12 hp Kohler. Finally had to resort to jumpimg the solenoid today. Got a bunch of the yard done today & took a break. Tried to start & no go. Even jumping the solenoid wouldn't work. Found no spark to the plug when turning over & headlights were off. Replaced the solenoid & no change.
Don't have a wiring diagram. Pulled the ignition switch out but with no diagram I don't know what is supposed to make to what. There is also something that looks like an old horn relay with two red wires on it.With the key on, I do have 12v on the red wires. Also have 12v at one of the red wires in back of the switch.
If I jumper direct from the battery to battery post to the starter, the motor cranks but no spark at plug & no headlights & no reading on volt meter.This is with the key in any position. Same thing if I pull the little wire off the solenoid & put jumper on the small lug.
As you can see, I'm just fumbling here. Could I have the battery wires reversed on the solenoid? Reason I ask is the replacement has the small lug in line with the post going to the starter. The original has it in line with the post to the battery.
Please Help
Thanks
Al
Please Help
Thanks
Al
