The attached pic shows the outside view of a 5 inch masonry pipe coming through a brick wall. This was installed apparently many years ago as a way to vent a water heater. Once the pipe reaches the outside though, it has what seems like a masonry collar cemented over the end, which itself is flush to the wall. The collar is painted red. Not sure if this was a common way of doing things back then,
Issue now is I want to use that pipe to hold a concentric pvc vent. It fits fine, but my question is whether I should cut off the collar and the end of the inner pipe, to be flush to the bricks. I think that's the more modern way, the maker of the concentric vent recommends a metal thimble be placed for the outer end of the vent to sit flush with. That would be hard to do with the pipe the way it currently is.
If so, what would be the best tool to cut it with? The problem is there's no room to cut between the collar and the bricks.
The inner pipe looks to be mortared or cemented into the block wall behind the bricks. Would it just be better to rotohammer that all out, and replace the whole assembly?
All input appreciated.
