My new to me resolute did not seem to want to keep the fire going when I put it into the horizontal draft mode. I would start in updraft until the griddle thermometer read 500 degrees. After about a half hour in the horizontal draft I would have bright red coals, but little or no flame the the griddle temp of around 400 degrees. I have to admit that I'm new to this and should have opened up the main air more. However I only had a 12 foot chimney straight up, and thought I probably could use more draft. Especially since I am in a very sheltered area. Yesterday I added a four foot section of double wall on top to bring my length up to 16 in hopes of increasing performance. I still have not had the chance to try it.
While I was at the store purchasing the extra length of pipe a gentleman told me that I would get allot more heat by putting a damper in the flue, so I purchased one. After looking around this sight it seems that many seem for and against putting in a damper. I don't think it's a necessity right now, as I wanted more draft not less. On the other hand I read that some feel that a flue damper is an added measure of safety in case of a chimney fire. For this reason alone I thought I would put one in, but would like to know if that would really be a mistake for any reason? As long as I leave it wide open, wouldn't it be like it wasn't there anyway? Does anyone else use a flue damper with an older Resolute?
Thanks for any advice.
