I just replaced the upper fireback (not the whole assembly) on my 1999 VC Encore 2550. The damper works fine when the stove is cold or when the stove is not too hot but when the stove is hot I cannot open the damper using the damper handle on the left side of the stove. It will not budge until the stove temperature goes down ( probably due to heat expansion). I have tried to adjust the damper adjustment in the middle of the damper as instructed in the manual (loosen nut and use an Allen wrench to adjust the center screw). I have tried to adjust in several different positions but the same thing happens. Any advise on how to properly adjust to eliminate this problem. There is another nut just below the damper adjustment screw. What is that for and does this have anything to do with it.
