I'm planning to have a 5kW wood burning stove installed. The regulations here in the UK don't require any air venting provision for older houses like mine because they're considered leaky enough to cope with stoves up to this size. Some stoves can be fitted with direct air vent kits to feed air directly from the outside but most suppliers/installers I've spoken to have little experience or interest in them because they're considered an unnecessary cost.
The way I see it, a stove that's vented from inside the house would be sucking air into the room. Ultimately that means sucking cold air into the house from outside. I guess it also means that noise from outside has a route into the room, as it does with an open chimney (UK regulations require that the vent can't be completely closed). I figure a direct air vent could prevent draughts and noise, while guaranteeing the best possible air supply at all times. Apart from the relatively small additional costs I don't see a downside but, as the attitude of the suppliers/installers is just "No, you don't need one", I've not really been able to have an intelligent discussion with anyone about it.
Are there any downsides to having a direct air vent for a wood burning stove?
