I am new to the forum and think the cumulative expertise here is probably the best. I have belonged to several forums (guitar forums, Banjo Hangout, etc.) and the experts like to hang there. So I am hopeful.
My wife and I wish to add a gas stove to an extension room (approx. 20'x14'). There is a chimney on one wall, but it is not functional and never has been. It is constructed of cinder blocks and goes from the concrete pad to the roof. The interior space is about 8x 16 inches, so it should fit liners easily. The stove would be about 31 inches from the interior of the chimney space. The stove exhaust needs to go 6" back to sheetrock, through empty space of 17 inches BEFORE hitting cinderblock, then 8" of cinderblock to enter the chimney space (total 31"). We want to fit the stove and exhaust stack under a mantle shelf to deflect heat from the wall-mounted TV above. The question: is there a requirement to have an exhaust rise before the horizontal run in order to establish a sufficient draft? Are there specs out there? We do not want to go vertical for 3 feet before running horizontal, which removes the mounted TV altogether. The stove would start 6 inches above the floor because of the hearth already being there and it is not easily removed.
I would like the answer to be the following: go up 1 foot or so, then back to the chimney interior (31"), then up the liner in the chimney to the exit about 15 feet up. This would give us room to install a mantle shelf at a convenient height and not interfere with the TV location.
Still looking for specs on these things.
Thanks in advance if you have any advice.
Larry
Larry
