Hi,
New member and very much appreciate any insight.
I recently removed my brick chimney as part of a larger renovation. I've kept the frame of the hearth and am installing a zero clearance fireplace.
The fireplace I have is a Kingsman ZV3600N. It's a "Vented" or B-vent model with a 4" attachment point. Down the road I plan to replace it with a double sided or see through unit, which will be direct vent.
Ideally, I'd like to install the venting now that will be required for the direct vent model. My question is whether I can use (as is or modified) a direct vent duct/pipe system to vent the B-vent fireplace?
Based on the pure sizing of the parts it seems like it should be possible (the 4" b vent is the same size as the exhaust air vent on a 4" direct vent). Could I also install now a 5" direct vent and down size to attach to my 4" B-vent?
Thanks
Thanks
