Direct vent vs chimney
DBNH22
437
NH
I am currently considering purchasing a Hamrann PB105 which I know cna be direct vented. I do however have two unused flues in my chimney. They were inspected last year and I was told they were in decent condition as they have never bene used (house is only 12 years old)
So which is better with a pellet boiler and why? Direct vent or through a chimney?
Thanks guys
Chimneys should still have liners in most cases, and required in most areas by code. If you have the open flue, its probably better from an aesthetic point of view. but cleaning a simple through the wall pipe is usually easier (and easier to install if you aren't going all the way up too)
Yes, most codes require you to have a chimney liner.
Thanks guys
The Harman name is the Holy Frail here..... So the spelling Hamrann is a little but of a play on words. I call them Hormone. But, for those that own one, they are sensitive (some, not you £oe)
Welcome to the forums. As for the liner. I would highly recommend one. That large clay lined chimney will need to heat up before it starts to pull the gases out. Which may play hell on the vacuum switch. I would make the vent as short as possible. Direct vent in my opinion.
Reactions: iceguy4 and Defiant
X2 as for direct vent...as for us being sensitive...NOT we just feel sorry for the "little people" ...Only kidding:ZZZLOL
I needed to use a chimney that was in great shape, I had really no other choice.. My dealer, who I'm quite impressed with, suggested that venting into a chimney would work around 80% of the time. After finding this forum and doing a lot of reading, I decided on a 4" liner right from the start. It burned great and never a worry. The only thing I haven't solved is an OAK. Next season!
Install one. You wont he sorry! :)
Check out the Selkirk DT chimney kit (called Masonry conversion kit) with the built in OAK. it works with your 4" liner, I have one and there is nothing better.
The vacuum cleanout is cool too!
  • [Hearth.com] Direct  vent vs chimney
I have my Harman XXV vented into an 8" clay lined chimney flue I had used for a wood stove. The XXV manual stated this could be done, the dealer gave the OK, and the building inspector said no problem. It's been operating with this chimney for 2 years now. Check the manual for your stove as well as ask the dealer and building inspector to see if the existing flue would be appropriate.
