Does anyone know what Size cleaning brush is required on Harman Accentra Insert
LobsterParty
56
Boston
Thanks for your help, trying to buy the right size.
It's a Harman Accentra Insert 42k BTU size 2006
First time owning the stove and wanna prepare for my first cleaning. I see alot of 3 inch and 4 inch brushes , somewhere online it said 2 inch.
Wanted to see if anyone knows the best size brush for the Harman , for a deep cleaning.
Thank you!
Depends on what you are cleaning. Your flue could be 3" or 4". And may go clear to the top of your chimney. If you are talking about the special brush that comes with an Accentra insert, for the flue passageways, it was originally 2" square. You may be able to use a softer 3" round , or you may have to get a 2" boiler brush. Or the factory brush,but they are very over priced.
Reactions: LobsterParty
I used 4 inch stainless 25 feet thru the Chimney and a nice cap. Thank you for the information
Reactions: Mt Bob
Don't know about an insert, but the factory one is about 17", and the tough guy is 16" and seems fine on the free standing Harmans.
Okay thanks. Just bought the 20 inch one.
What do you think about this video?
He bought a power drill harbor freight plumbers snake
Good video. he is showing a partially clogged stove, a stove that has not been properly maintained. Normally, you would brush those side passages every cleaning, and not have to remove the insert,remove the combustion blower, but 1 time a year. Another handy tool is a cheap bore scope(harbor freight) and you can look up in stove passages, to check for cleanliness.
My harmen accentra insert pellet stove was working perfectly fine for a month.. and today I topped off the pellets when I woke up. Everything was working flawlessly and then I watched the flame just die down and basically go out. Everything was cherry red and smoking, but no flame.
Wonder what's going on and if something broke..
I turned it off to cool down. So I can clean it out with the vacuum
