Does anyone recognize this pellet stove insert?
hamhock75
12
California
I am told it is probably from around the late 1970's.
[Hearth.com] Does anyone recognize this pellet stove insert?
Reactions: Ssyko
Has a lot of Whitfield/Breckwell properties but believe it or not it’s probably newer than the 70’s. Is there a sticker inside the lid or back of hopper?
I did find this which may help with the quest😃
The first residential pellet stove was invented in 1973 by Jerry Whitfield, an engineer from Washington State. However, widespread production and commercial availability for the home market did not begin until the early 1980s, specifically around 1983.
hearthsidepatio.com
hearthsidepatio.com
Initial Invention: Driven by the 1970s oil crisis, Jerry Whitfield developed the technology to use recycled wood byproducts (pellets) as an efficient alternative to traditional fuel.
Market Entry: The first home-sized pellet stoves were marketed in the early 1980s.
Early Models: Brands like Lopi (founded in 1979) and Whitfield (Pyro Industries) were pioneers. For example, Lopi Stoves lists some of their discontinued pellet inserts dating back to 1991 (such as the 400 PI model), though wood-burning inserts had hit the market as early as 1976.
Regulation Influence: The popularity of both stoves and inserts surged after 1988, when the EPA began enforcing emission standards that made cleaner-burning pellet technology more attractive than traditional wood stoves.
Is that not an ID plate at the bottom of the controls? Or is it vents?
Reactions: Ssyko
I couldn’t find anything on it other than “heat zone caution”
Reactions: Washed-Up
The pellet stoves Jerry Whitfield made were work horses! Very simple and uses common parts for easy replacement.
Some pretty cool Americana tight there! Especially for us pellet heads!!!
Looks almost like the old Breckwell analog control panel, and the gold decor, I'm guess late 80's, early 90's. Anyone got the answer?
I have been offered the above pellet stove insert. I currently have a Whitfield WP2 Advantage insert. I was hoping someone would recognize it so I could determine if it would be an upgrade to the WP2. I will probably have to pass if there is no information about it. Nothing on the exterior has a name on it unfortunately.
I would have to agree with you. The old Whitfield insert is a great stove (not to mention you know what it is) a good going through it should serve you well
Reactions: ericofmaine
The Advantage series (esp Adv 2T) were exceptional heaters. Are parts still available? Not sure, but if you have one in good condition, I would keep letting it do its work for you.
