First of all, if re-lining a factory chimney is not possible/safe, forget this whole idea. BUT
I am cosidering replacing the factory-built fireplace with either an Osburn Stratford or a Napoleon NZ26. for the chimney---the current setup is an unknown metal pipe---that is probably double-walled and the ID is 10". I am thinking about installing a Flex-King or Homesaver 6" liner with the insulation blanket. Is this acceptable? I am primarily concerned with safety. I am also considering DIY. as far as the zero clearance units, there is clearance behind the existing unit, I just feel more comfortable with them.... we don't need a huge fireplace, but would like to supplement the home's heat with wood. thanks
