Dollar bill test question?
John Fortier
450
What exactly am I looking for with the bill test? Should I be able to pull it out with some effort, no effort or not with out tearing it? Reason I am asking our stove was serviced ( total clean ) and we had a 3/4 " that was replaced with a 1/2" as tech said he has never seen the 3/4" . I tightened the latch as far as it will go and hence my question. Is a phone call needed ..... an answer here will tell. Thanks!
There should be a LOT of drag on the dollar bill.
If it's totally stuck to the point of tearing when you pull on it, that's not a bad thing,
but too loose is not good...
Thanks Daksy...Another question..as the stove heats would that seal the door tighter?
Metal DOES expand as it's heated, but the expansion is not enough to seal a gasket gap.
Again I thank you.
If it calls for 3/4 inch it should have 3/4 inch. I guess if you scrunched up a 1/2 it would work for a while. Ive always been able to pull out paper with some effort sometimes it will tear.
Take a lighter and go around the door and see if the flame gets sucked in that is another way to check.
Reactions: Owen1508
Thanks all ..will try the lighter test.
