Hi, Some friends want to give me a morso 1125 stove which has never been used. It would be going into a new which is still under construction, and money is short. I have heard some fairly good things about this stove on the forum, but what I eventually want is an EPA type with high efficiency and window. But the cost difference is hard to ignore.
So... Can I install a 6" pipe and chimney with a 8" converter now, so that when I have the money for a new stove I can keep the chimney unchanged? (the morso uses 8" I believe, and the modern stoves all seem to prefer 6" , right?)
The house is a 1.5 story 800 ft studio cottage with loft. House has cathedral ceiling, and the chimney will be installed near the peak at about 21' above the floor. Location is at 4000' elevation in the Hawaiian islands . Winter nights get into the 40s. So the burn pattern will be like most area's spring/ fall conditions. Mostly to take the chill off and keep the place from getting too damp, it will be my only source of heat. I will be burning eucalyptus which is abundant on the property.
Any advice will be appreciated. Thanks.
