Door gasket - first break in fire - normal?
sunglider
38
Andes, New York
I did the first break in fire with a new Jotul Rangeley TL50 last week. Got the stove up to 200-250 and let it cruise out as per the manual. Several days later when I wanted to do the second break in fire, I had a lot of trouble opening the front door. The gasket was almost bonded to the front of the stove. I was afraid the gasket was actually going to pull off the door. It left a film on the front of the stove too.
Is this normal? Should I clean off the front of the stove where the gasket meets it? If so, with what?
Thanks in advance
Never experienced that one - giving this a bump as I'm curious about the responses too...
I've had that happen on our Castine when it was new. It didn't happen again so I forgot about it.
The door gasket on my brand new rangeley stuck a little too. Got through the break-in burns and subsequent cool downs, and now everything is fine. Probably just some extra glue from the assembly.
I think Diane nailed it.
Clean inside with a wire brush and it should be fine. But you say it is on the front of the stove. Try steel wool or emery cloth.
I read the manual for my Avalon Rainier from cover to cover during my break-in fire last month. It mentioned how the paint curing causes the whole thing to smoke a bit, not from the fire, but from the paint curing. It also mentioned the possibility that the front door gasket could stick to the paint during this break-in period. I didn't experience the door gasket issue, but it could be a paint curing thing?
I ended up calling the shop that installed it. They said it sometimes happened - a bit too much cement and not to worry about it. It never happened again.
Nice stove, by the way. Its doing a great job heating the place and hasn't even had to work that hard yet.
Reactions: Backwoods Savage
Im new to burning wood, first stove, 2nd break in fire in a new rangeley. My front door gasket stuck as well, but mine actually separated from the door. just wondering if i need to change it or try to cement it back in? Thanks
  • [Hearth.com] Door gasket - first break in fire - normal?
It happens sometimes. The paint gets tacky as it bakes in then solidifies as it cools. Just cement it back in that area.
I believe BK's princess manual states to open and close the door periodically during break in to avoid this issue.
