We have a PE Alderlea T4. I replaced our gasket 2 years ago; the original lasted 3 years. I did it well- took the door off, cleaned it thoroughly and cured it back on it's hinges. Now the gasket/roping itself looks fine but the cement hasn't held. It's loose along the top. I'm thinking I can re-cement the top edge and get another season or two before replacing the whole gasket. It seems like these things should last longer. What do you think- fix or replace? How often have you had to replace yours?
How often do you clean your chimney? We burn mostly well-cured hardwoods but use some pine during shoulder seasons and for fire starters. Half of the adults here think it needs done annually but the other half thinks with our burning habits that every other year is sufficient. We just didn't see much debris last year.
