Double-sided wood stove options
Ansky
121
central CT
Hi, I currently have a double sided gas fireplace (propane) that is in a masonry fireplace and chimney. I'd like to convert it to a double sided wood stove. Any suggestions on where to start? I think my options are probably limited. It's a large opening, so I think I can put a free standing stove in that space (instead of an insert). Any suggestions are appreciated.
Got a picture and some measurements?
Sure. It's 38" wide, 30" tall, and 25" deep.
I'll snap a pic tomorrow.
Are you wanting to set a freestanding stove up against the opening on one side? You aren’t going to find any 2 sided stoves or inserts that will fit into a Fireplace. Many people put a decorative cover on one side and install an insert on the other.
I found this one. This is the right idea.
(broken link removed to https://supremem.com/vision.php)
Even if it will physically fit, is it approved to be installed inside a Fireplace?
They use an air control that acts somewhat like a thermostat/timer for quick start ups. The additional heat would mess with it I think.
Not to mention it’s 38.4” tall not including the flue collar.
you're right. the hight alone makes it not a viable option.
It does have a built in barbeque grill though. That should count for something.
Here's some pics of the current set up.
[Hearth.com] Double-sided wood stove options [Hearth.com] Double-sided wood stove options [Hearth.com] Double-sided wood stove options [Hearth.com] Double-sided wood stove options [Hearth.com] Double-sided wood stove options
