I saw our local town highway crew pulling up an old corrugated metal drainage pipe (which could have been reused) from under a road and started thinkin' this might make a good storage solution. Build a square form on top of insulation board and pour in concrete. While it is still wet place one end of a culvert pipe into the cement and let harden. You have a tank which doesn't need reinforcing nor should it need a liner if you coat the cement. Build a square wall on top of your square cement and insulate the void between the metal pipe and the wooden walls with foam or whatever. You could make the wooden walls out of 2X2's because they have no pressure aginst them and put rigid board insulation on the outside for even higher R's. The top could be made to rest on the square walls.
I called a local supplier and found that a 6 ft diameter by 5 ft long piece of galvanized corrugated pipe is about $500. I figured this would give about 1000 gallons storage. He also has an aluminized coated pipe for about $10 a linear foot more. This is the only price I got, so it may be cheaper someplace else, but 50 cents a gallon ain't bad. I wouldn't rule out reusing something the town dug up. The foreman told me they do it because they are rebuiding the road NOT because the pipe is bad!!
This might be a good way to build underground storage with good stratification and use even longer pieces of pipe for more storage. The pipe comes in diameter increments of 6 inches. So a 5 ft diameter by 7 foot length would also hold about 1000 gallons.
Kinda thinking out loud here and wanted opinions.
Gary
Gary
