I have a brad new Drolet pellet stove and it has been giving me nothing but problems, black soot in the house and blocked furnace filters. I am trying to work with their support team but no solutions yet.
Last year i ran it for a bit and it absolutely covered the side of the house with soot, according to support this was due to the venting ( tee, 5’ rise, 3’ horizontal with a 45 degree termination) changed to tee 5’ rise, 3’ horizontal, tee, 3’ rise 45 degree termination (all sealed with tape)
The vent change seems to have helped the exterior sooting but it could also be because I haven’t had to run the stove as high as last year yet. Flame doesn’t seem lazy at all, but I can see black edges around some flames.
Is it normal for there to be a lot and I mean A lot of black soot inside the unit (traps and venting pipe) not ash but black super fine but thick soot in side the unit?
Now I know it’s not normal to have soot inside the house and it points to a leak, on startup there is smoke coming from the “air wash”, and smoke coming from behind exhaust blower , problem is Drolet says this is normal and means the venting is dirty or clogged. I’ve cleaned it so many times and I just can’t agree this is normal, seems like something is seriously wrong with the unit and they are failing to fix it. When the unit is running I can’t seem to smell or see any smoke or soot but my furnace filter disagrees and gets grey to black I’n less than 24 hours…
Anybody else have this problem with Drolet? Is having black soot normal? Even in the unit? Actual chunks get formed on the venting in less then 500 lbs. burned, a bang on the vent causes chunks to fall down, normal?
	![[Hearth.com] Drolet ECO 65 - so much black soot!! [Hearth.com] Drolet ECO 65 - so much black soot!!](https://www.hearth.com/talk/data/attachments/304/304463-7b010baaa5aae60a0f44e970c1b320e7.jpg?hash=rz_Q7jK8X2)
