Dose any one have any information on the control board to who it is made by and the programming,belive the fan is not running at correct speed
rosco said:Hi dave been in trouch with SBI they will not give any info on control board............
If you rstove is running on "low" the sooty flame will dirty up the glass pretty fast. If you are running it on med or high it shouldn't soot up. Some stoves have an "air wash" to help keep the glass clean but even those aren't fool proof.rosco said:Robby,,,,,,,,,,,,,, thanks mine is the same it is working and runs the same as yours, I want to get the info in case I need to repair the control board, I am a Electronic Tech and try to get all the info I can, plus on other stoves my buddys have the exh: fan seems to be running the same but as u go up on the temp setting the induction fan runns faster to keep a cleannner flame, more pellets hotter flame should us more air......thanks for the info
Bob
Pete Not looking to reduce speed but spec's and info on the control board to see why the glass on the door smokes up asap after the cleanning
Bob
My St. CroiX Pepin is a pretty simple stove, too. It has a control board but only has a "heat" (feed rate) control and a rotary fan speed. And a manual pellet feed/high fan rocker switch.rosco said:Krooser..........
Hi..........
A lot of the stoves that don't have auto controls seem to burn a lot cleanner so that is why I am looking for the spec"s would like to add a mech: control run the blower
Bob
Hi..........
Bob
