I got one of these with the idea of controlling either the fan on my heat pump to circulate heat or a seperate 120 volt fan, by placing the sensor near the discharge of the convection fan tubes. But after bench testing it, I may use it to control my CB1200i directly. It has a wired remote temperature sensor that is 8 foot long and can be extended to 200 feet. It has a programmable temperature swing that I haven't been able to find in a "normal thermostat". It can be set to swing how ever many degrees you want. It can be hidden from view with only the sensor being exposed to sense temperature. Its a little pricey compared to a thermostat but it has a lot of potiential. Another thing I thought of doing with it , is to use it to use outside air temperature to to control a thermostat so when it gets cold enough the pellet stove is the primary heat and when it warmer the heat pump does the work. Any thoughts?
(broken link removed to http://www.etcsupply.com/ranco-etc111000000-digital-temperature-controller-p-86.html)
