Duravent Piping adapter
lodtrack
8
Moonbeam Ontario
I am looking for an approved adapter to go from a 4" Duravent brand pipe to 7 inch Selkirk Class A chimney. If there is an adapter that converts to standard 7" single wall stove pipe that would be even better. The purpose is to tie into my existing chimney rather than vent through the wall. Any thoughts?
This what you're looking for?
(broken link removed)
I used the same one as that (although the 8" size). If that is the correct one to adapt to his stove pipe, then he will most likely need these also....I went from 4" Duravent to 8" Metalbestos and Eric at Kinsman hooked me up with these part numbers, so the ones for 6 or 7" will be different (see part #'s in pics):
  • [Hearth.com] Duravent Piping adapter
Thanks for your help and information.
