durock multiple layers
rob bennett
147
Lynden, Washington
Howdy-
I just realized that I am going to need probably 5 layers of durock (old style) for my hearth. I can't find Mircore locally. If you have done this, did you screw layers progressively to each other with mortar in between? Or should I just screw them together and call it good? Or just mortar them together? I need a K value of .84 I believe. Its for a keystone I'm putting in.
Thanks
Last I saw durock was 0.20 per 1/2" thickness. The woodstock keystone needs 0.84 for hearth R-value? I thought they only needed ember protection.
I also could not get micore in WA so I used "dead air space" per the hearthstone manual.
4 layers should do it if the goal is to achieve that high rating. Is this required? Cement board's R value .52/1" or .26/ 1/2" according to USG and Craig's chart. But for some reason thechimneysweep has it as .20. I would go by the mfg rating.
Here is the spec:
"Space-saving Durock® brand cement board is listed by Underwriters Laboratories, Inc., for use with UL-listed
solid-fuel room heaters and fireplace stoves. Used as a wall shield, Durock cement board reduces by two-thirds
the manufacturer-specified clearance (minimum 12") between the room heater or stove and a combustible wall
surface. Durock cement board may also be used as a floor protector in place of one layer of 3/8" thick millboard.
(Having a thermal conductivity of k ≤ 0.84 Btu in./(ft. ² h °F) in the minimum dimensions specified by the room
heater/stove manufacturer.)"
(broken link removed to http://www.usg.com/USG_Marketing_Content/usg.com/web_files/Documents/Prod_Data_and_Submittal_Sheets/CB198_Durock_Cement_Bd.pdf)
and specs here on page 2:
(broken link removed to http://www.usg.com/USG_Marketing_Content/usg.com/web_files/Documents/Prod_Data_and_Submittal_Sheets/DrckCement_Board-Submittal_Sheet_CB399.pdf)
1/2" Durock R= .26, K value = 1.92
Highbeam you are exactly correct. For Woodstock stoves only 1/2" sheet of cement board is required per their installation instructions.
  • [Hearth.com] durock multiple layers
The instructions appear to require that sheet of steel as well. Ugh, why can't they just give us an R-value requirement and let us be creative?
The back plate says the floor protection "must me be a minimum of 3/8 of an inch thick with an K value of .84"
So we are not talking about R value. k= 1/R according to an article on this site. So I am looking at 2.3 inches of durock to equal that.
If that is the case, that diagram in the instructions and above is really misleading. 1/2 inch cement board only works if that cement is micore 300.
I'll call the friendly folks at woodstock tomorrow. I'd be pretty frustrated to finish my pad only to find out it didn't meet inspection.
Please let us know what they say. I am confused. We have USG saying:
"Durock cement board may also be used as a floor protector in place of one layer of 3/8” thick millboard.
heater/stove manufacturer.)”
In the Keystone manual we have Woodstock saying:
"1) a 1/2 inch layer of an approved non-combustible insulation board (such as
DUROCK cement board or WonderBoard Backer Board), then apply
2) 1/4” or more of a decorative, non-combustible material such as tile, slate,
stone or brick."
Yet the Hearth.com chart is calling for 2.3" of cement board to achieve k.84.
I could be completely befuddled, it sure wouldn't be the first time, but if k is the reciprocal, then doubling the thickness would half the k value, no? If 1/2" = k 1.92 then 1" = k .96. Somethin's goosey lucy.
Well if I have my math figured out, and the calculation right
1/2 inch durock has an r of .26
so 5 layers of durock .26+.26+.26+.26+.26 = 1.3 total R
1/1.3 = .769 (lower k = lower heat conductivity)
Either way I am confused
Okay, so if I build what the page in BeGreen's message says, I'm good to go--no chance of issues? If this is the case, why do some hearth pads measure 1.25" in thickness? I saw some this past Saturday at a stove dealer in Clovis for $495.00. They were very nice, but for $495? Hody Cow! If the plywood, durock, tile will do just as well, why $495?? BTW, is this durock the same as concrete Hardi-Board or not. If not, can it be gotten at Home Depot or Lowes? Thanks--
This is not the same as HardiBoard. Ask your HD where they keep the pure cement board. Durock or Wonderboard, and not the lightweight next generation stuff.
A good hearth pad can cost $500 retail. You can do the same for about $80 material, your time and labor, depending on the tile chosen.
I bonded my layers of Durock together with thinset and then screwed them as well. It came out very rigid.
I agree with BeGreen. This is all very confusing business. I went through this about a year ago when installing my Jotul 3TD. I had to convert k-value to R-value and then use the Hearth wiki chart to determine the R-value of 1/2" durock and 1/4" tile. I used two layers of durock (bonded with thinset and screws) followed by a layer of tile. That put me slightly under the required R-value for my stove. However, in practice, I can place and keep my hand on the tile under the stove with a roaring fire going and the tile is not really even warm to the touch. I'm all in favor of following manufacturer's recommendations but sometimes I think the lawyers rather than the engineers come up with the requirements.
ChipTam
You may have already taken care of this, but hardiebacker has a rating of .13 per 1/4" or .26 for 1/2" (broken link removed to http://www.jameshardie.com/homeowner/products_backerboard_halfInch.shtml)
so that would work for you as well.
If it help I also used thinset between the mess of stuff I built it worked out just fine.
So, the 1/2" HardiBoard IS okay? I've been mulling this over a lot and was wondering exactly what it is we're trying to protect the floor and sub-floor from. Does anyone have a handle on this and exactly how much of a danger we're facing?
My floor is 1/2" tile 16" square laid over a plywood subfloor. For the pad maybe 1/2" plywood, then a layer of small-cell expanded metal, then 1/2" Hardi-Board, screw that together and then set more of the floor tile on top of that with the thin-set. The thinking is that the expanded metal layer would be a barrier to and/or disperse the heat. In addition, I thought I might use the leftover 1/2" HardiBoard pieces to raise the whole shebang off the floor creating an airspace for more heat dissapation. What is the braintrust's thinking on this arrangement? Is this overkill? If so, would it be worth it? I don't mind overkill if it's not a killing cost.
Then how can we know we've accomplished the objective?
ChipTam
So, is that roughly how we can tell if there is a potential problem? If one can place one's hand underneath the stove, as in this case, does that mean that the underlying surfaces are safe? If one created an airspace underneath the protection pad, would that help or is it radiational heating we're dealing with? Just trying to figure this all out! Thanks--
What does woodstock say? Being so high on customer service I suspect they can send you a memo or TSB to show the inspector. I could swear that they also required a sheet of steel in there which I always thought was overkill.
Here in NH The only place we could find Micore, was a company that specializes in acoustic celiings. Do you have that type of company in your area? This all gets a lot easier if you can find Micore. - I just went through this scenario myself this year, with the help from this forum.
I don't know if these are near you but they are micore distributors I got from Micore/USG website.
BUILDING SPECIALTIES
14980 NE 90TH STREET
P O BOX 350
REDMOND, Washington
Phone: 425-882-3116
Fax: 425-881-5830
# Micore
BUILDING SPECIALTIES, INC.
EAST 6819 MISSION
SPOKANE, Washington
Phone: 800-909-2526
Fax: 509-893-0866
I was just perusing Quad docs and think I might have seen that for the Quad Isle Royale?
It's ugly formatting but this was cut from the fireview manual. They still require the sheet metal. Oddly omitted from the other stoves it seems.
Your Woodstock Soapstone stove must stand on either:
1) a hearth of solid masonry (brick, stone, or tile supported by concrete),
2) a prefabricated hearth pad listed to UL standards. These pads can be placed on
top of a wood or carpeted floor. (Woodstock Soapstone Company carries a
selection of these pads.)
3) a custom designed pad made up of approved non-combustible materials which
will protect the floor from sparks, hot coals and ashes; and prevents heat from
being radiated onto the floor underneath.
If you decide to build your own hearth to go over a combustible floor, start with a
plywood base. Over this apply:
1) a layer of 24 gauge galvanized sheetmetal,
2) a 1/2 inch layer of an approved non-combustible insulation board (such as
3) decorative non-combustible material such as tile, slate, stone or brick.
Weird. The screenshot posted above is straight from the Keystone online manual. No mention of the metal for that stove.
If you use the metal you can get away with one 1/2" layer of cement board? I'm suprised they don't say anything about a need for air space. This sounds like the way to go.
I don't think an air gap is ever required.
