DutchWest 2461 Inner Top Web Air Gap between Web and Stove Top???
whereditgo
3
CT
Hello All,
My DutchWest 2461 Wood Stove was in dire need of attention (leaking gaskets and creosote build up/clogging).
Removed most of the creosote, cleand flue and stove outlet and replaced gaskets/seals on Side door, Front Door, Ash Pan and Damper.
Re-built the Cat. Replaced Air distributor (part 8 on diagram), Baffle (part 9 on diagram), Interam Gasket (part 54 on diagram). Sure this was due to time/heat (original 20+ year old parts).
When installing the Inner Top Web (part 6 on the diagram) there was a 1/4 gap between the bottom of the Inner Web and the Top of the Inner Top (part 5 on the diagram).
Is this a design feature (blowoff/bypass for the cat) or a warped web (web looked fairly straight, but slightly mis-align on the 45 degree edges)?
I sealed off the gap with gasket/cement and now the cat burns extremely hot with dry/seasoned wood (~1700 degrees).
Stove seems to be working as new other then Cat running very hot (with primary damper slightly cracked open and ~2 turns on Combustor/Cat Air Inlet).
Any input would be appreciated.
Thanks
[Hearth.com] DutchWest 2461 Inner Top Web Air Gap between Web and Stove Top???
Those 2 gaps are supposed to get tiny interam gaskets but I've been debating just hitting them myself w some furnace cement on my current rebuild
Hello All,
Thanks
I recently rebuilt mine. Are these the gaps you were talking about? (pics below) I was debating sealing them with cement but figured for whatever reason (maybe possible warpage?) the manufacturer called for interam gaskets so that's what I used. My web went across where the damper gasket is perfectly and I got both slots exact same width before tightening the brackets that hold it up.
