Hi,
I searched for anything Earth Stove and found it to be an old pellet stove. This after I purchased a used Earth Stove Model WP 50 today. It seems the three speed setting switch has all three settings the same HIGH. I was wondering if anyone had a manual on this dinosaur and willingness to help me slow down the auger speed. I suspect the circuit board switch but have not dug out volt ohm meter to check switch out yet tonight. It seems to work fine other the the auger runs all the time and switching from low to full doesn't change a thing. Also what is the 15 second on/off light signify? The board model # is OII 500S if that helps.
Thanks for your help.
Den-Den
Den-Den
