How important are these? and what do they mean exactly? Comparing 2 inserts, I see one rated at 84.7% (enviro boston), and the other at 76.9% (lopi freedom).
Does this just mean that using a higher efficient insert will take less wood to get the same amount of heat?
Most will also tend to over-rate how large of a home the stove will heat. They also won't tell you that you should already have your wood well before you buy the stove! This is extremely important.
