Hi. I have an eko 40. I have been running this boiler for a year and a half now with relatively no trouble. My problem is I have a good gasification fire going but the system is not heating up. I have 1000 gallon storage that is taking everything from the boiler. Inside the room the stack temp is 220 the same as it has been for a year and a half. The top of the stack is 153 degrees. I come home from work and the system is usually 140 degrees I light a fire and in about 5-6 hours the system is 185 degrees. Yesterday I did my usual routine and 10 hours and a few extra loads of wood later it was only 175 degrees. This problem occurred all of a sudden. I bled the system of air and did get a little out. I'm thinking maybe the heat exchanger is plugged up? The wood is dry and burns good and the system never idles I shake the turbulator handle every few days. It just seems like I should have noticed a gradual decline in efficiency over a period of time not in a day. If it is the heat exchanger how do you get that clean? Also can someone explain to me the chains people are talking about that they hang in the heat exchanger? Keep it dumb for me please I'm not real familiar on all the professional terms lol. Thank you all
