I toying with the idea of putting a few solar panels to the roof and adding a heating element to my 500 gallon water tank that I use with my Vigas 40. Has anyone done this yet?
Sounds interesting something I'd like to try !I toying with the idea of putting a few solar panels to the roof and adding a heating element to my 500 gallon water tank that I use with my Vigas 40. Has anyone done this yet?
You may not have the right voltage if you get a 220VAC heating element. And if there is such thing as a DC heating element could be many amps.If you mean just directly wiring the DC output of the panels to the heating element, it should work to give you a few extra BTUs as long as the wattages are matched reasonably enough. Make sure you have some sort of a high limit hooked up and ideally a low water cutoff too.
Many people who "have solar panels" are referring to a grid tied system, and if that's what you're doing you would get many more BTUs per watt by running a heat pump.
Sure the heating element won't put out it's rated power, it will just consume whatever current the solar panels can give it. Which is why it needs to be rated high enough to not add too much resistance to the circuit and not go over its rated power when the solar panels hit their peak output.You may not have the right voltage if you get a 220VAC heating element. And if there is such thing as a DC heating element could be many amps.
Vsquared/r = the power so it's not going to put out very much power without the right voltage. I never thought about the galvanic effect with DC. That could cause more problems than its worth.Sure the heating element won't put out it's rated power, it will just consume whatever current the solar panels can give it. Which is why it needs to be rated high enough to not add too much resistance to the circuit and not go over its rated power when the solar panels hit their peak output.
A heating element is just a piece of resistive wire so it doesn't care if it gets AC or DC. However you may have to worry a little more about galvanic effects with DC if it's operating in a moist environment.
You'll generally get maximum power when the load resistance is approximately equal to the source resistance which is the solar panels' internal resistance. Voltage will rise and drop with solar input, as will the heater's output power.Vsquared/r = the power so it's not going to put out very much power without the right voltage. I never thought about the galvanic effect with DC. That could cause more problems than its worth.
Do you know what options you have for the heating element? I tend to think you would need quite a few panels to build up the voltage.So what do you think. Is it worth looking into it? I don't think i want to go full solar panel array for electric but possibly one or two panels and not grid tied at all.
One other option is a solar water heating array. When I bought this house it had two large panels on the roof and they had it hooked up to the oil boiler. I don't know exactly how it worked, as it was all de-commissioned and I had it removed when I did the roof. I think the "hose/cable" had heat trace in in.
Are you thinking of the ones that heat up water?This is interesting I did not know that solar panels can create electricity ?
That's what I was thinking ,but have a solar panel on the travel trailer to keep the battery's up also hag the same on the sailboat and that was twenty years ago .Are you thinking of the ones that heat up water?
Yes, they have continued to make solar panels that make DC power. There are at least three different types now. If you look you will see them covering roofs. They have developed the electronics too. Now people are tied into the utility and can "make money" or reverse the meter. There are also large industrial solar projects. I have a couple of small ones like yours. The biggest I have is 100 watts and it's portable. I don't have them on my roof as you need lots of money to buy and install them, or someone else installs and owns them under a contract.That's what I was thinking ,but have a solar panel on the travel trailer to keep the battery's up also hag the same on the sailboat and that was twenty years ago .
