For those of us that have inserts, you know what a pain it is to pull it out to work on for cleaning etc.
Both my combustion and convection fan wiring are on the same side (left) and all my wiring goes to a terminal block in the rear. If the wiring was not in play I could pull both fans for cleaning without having to pull out insert completely and disconnect the wiring at the terminal block
So my question is could I splice the wires closer to the fans using terminal type connectors (male/female) using the proper gauged terminal? I realise that terminals should not touch
Any thoughts?
Any thoughts?
