It's nice to be reminded from time to time of some of the basic facts that we are dealing with. This chart from The Woodburner’s Encyclopedia (1976) shows radiated heat per hour per square foot as a function of surface temperature. It explains to me again why I was so fond of the little Jotul 602 for so many years, which I normally ran at surface temps in the 800º-900º range...
The amount of heat emitted per square foot is dependent on the temperature of the radiating body. Because surface temperatures are lower, massive heat exchangers need a lot of surface area to radiate useable heat into a room.
TEMPERATURE.....TOTAL ENERGY
......OF................TRANSFERRED
SURFACE (º F).....BTU / Hour - ft 2
80º ......................... 15
100º.........................51
150º.......................168
200º.......................315
400º.....................1230
600º.....................2850
800º.....................5430
1200º...................9370
(sorry, it's hard to format columns here)
So... if you operate your stove in the 600º range and want to double your heat output, you can either a) run it at 800º or b) buy a stove with twice the radiating surface area.
The heat will always flow from hot to cold... and big cold surface areas can suck alot of it!
