This year I moved into a new house that came with an Encore 2040c stove installed. It was manufactured in 2019, but it looks like the previous owners were rough with it.
I've redone all the gaskets, including the ash pan, doors, griddle, and flue collar.
The issue I’m having is that the stove gets too hot. When I compare its performance to the manufacturer’s information and to YouTube videos, there's a noticeable difference.
Three splits in the stove with the cat engaged and the air at 0%, and I can easily see griddle temps of 600 to 650+.
So seeing the data on here with overnight burns where the griddle temp barely scrapes 450 or 500 and cruses at 300 is amazing to me.
With the bypass closed and the air control at 0%, I still see fast moving yellow flames in the firebox.
I've checked for leaks using the dollar bill test and a stick incense, no leaks that I could find.
I also tested the primary air control flap at the back. It closes fully, and when closed, incense smoke gets pulled into the intake where a blower would be installed, not into the air intake.
At this point, I'm out of ideas about what could be causing this.
Thanks for any advice, this forum has been a great source of information.
