After my stove rebuild this year, I had to replace the primary thermostat and cable. Once done, I found the stove seemed to not be getting enough air, so I adjusted the thermostat cable adjustment in the primary air intake in the back...hoping to have a bit more air flow. Now, I'm getting more air, but this is strange;
When the stove is cool, the air intake lever will spring back towards the rear of the stove...effectively limiting the amount of air into the stove. As the stove heats (and it burns very well in non-catalytic mode), the lever is then capable of being moved forward without springing back.
I'm not a pro here, but this seems like the action of the bimetallic spring is working backwards....or is it just the result of my having the cable adjusted too tight?
I had installed a steel cat when I did the rebuild, and have had a problem with it lighting off consistently. Condor was great, and I am going to install the ceramic catalyst this week, so it is a good opportunity to fix the thermostat if I have something wrong.
FYI....griddle temps will stay at about 550 in both cat and non cat modes with a well stoked and hot stove...the stove will not overfire under any circumstance. I was unable to reach these temps before tweeking the thermostat adjustment.
The stove seems VERY tight after the rebuild, and FWIW, the steel cat seems to restrict air flow more that the old style ceramic combustor.
Do I have this installed wrong or is there an issue somewhere that I am missing?
Could it be a cable placement issue? I have the cable running below the thermostat spring...which seemed correct based on diagram....but my cable was broken when I replace the spring so not sure what it looked like before.
Also, could I just now have a stove that is too tight if I have to tweek the thermostat cable adjustment?
THANKS
THANKS
...removed the inner panel when I had it apart for the new cat and went through the install again from scratch. Running like a new stove.
