englader 25epi
Dani
12
West virginia
I just bought an englander 25epi I have ran it for the 4 the time. My first question is is the fan motor suppose to speed up and down on its own and it's been shutting down in the middle of the night. Any suggestion
When the exhaust temp starts getting too high, the convection blower goes on high by itself to cool it down........
You can turn your convection blower up a bit to keep it from happening but it's really not an issue....really the worst part is listening to the stove jump on high for a while. Not sure why your stove is shutting down, are you getting an error code? Does the burnpot have any pellets in it when it happens?
You can turn your convection blower up a bit to keep it from happening but it's really not an issue....really the worst part is listening to the stove jump on high for a while. Not sure why your stove is shutting down, are you getting an error code? Does the burnpot have any pellets in e burned pellets in the burn pot
It has pellets in the burn pot that has not been burned. I hope it's not something wrong with it I bough it to replace my old one. I hat to take it back. No codes
If you are burning on low it might not be feeding enough pellets to stay lit........is there a lot of un-burnt pellets in the pot? You can try turning the stove up a bit, unless it starts cooking you out of the house
What do I do with the damper my other on didn't have one it handle is right udder where the heat blows out do I need to do anything with that
That's not a damper, that handle cleans off the heat exchanger tubes.....you'll need pull on that back and fourth every day or two to keep the tubes clean. You will also need to remove the baffle every so often and vacuum out all the ash that accumulates there. If you haven't already done so, I would HIGHLY recommend reading the manual.
