OK, Here's an update. I got home from work and started cleaning the stove as promised. I went to a local hardware store and bought several boiler/furnace cleaning brushes of varying sizes. I took the stove apart and cleaned EVERYTHING. All exhaust passages included, except I didn't clean the exhaust blower as I am waiting for a new gasket. I removed the burn pot cradle and cleaned it too.
 I found the burn pot had a few flaws in it. It was welded incorrectly and there was a large air gap on one side of it. There was also a lot of welding slag that prevented the pot from sitting tightly against the cradle. I ground off the slag, and welded the air gap closed. There was A TON of ash behind the welded steel plate in the stove. After a good cleaning, I re assembled it and it is running AWESOME! The ash is being blown out of the burn pot, the flame is bright and active and the glass is staying clean! I am very pleased! I will continue my cleaning once my exhaust blower gasket comes in. But until then, THANKS EVERYONE WHO HELPED WITH THIS DIAGNOSIS
